Column not Going to Base Constraint
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
BigPicture045
214 Aufrufe, 1 Antwort
I need these columns to go to the given constraint. Currently, they are stopping at the walls. The column in the front which goes to the floor is correct.  Cut geometry not available for column to wall.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: BigPicture045
Joined? Reverse Join Order.
