Column Line Weight problem
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Marie.j03
698 Aufrufe, 3 Antworten
Hi community,
How cn I fix the line weight of the common lines of the columns inside the walls? the cut line weight changes all of it
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: Marie.j03
@Marie.j03
You need to join them ... Modify tab >> join geometry >> join
Otherwise use architectural columns ... these join automatically
Nachricht 3 von 4
Marie.j03
als Antwort auf: RDAOU
Thank you for the quick reply. that worked but is there no other way to do it without joining?
Nachricht 4 von 4
RDAOU
@Marie.j03
You can nest a Detail Component into the column with different line weight on each side/half-side and a masking filled region for the fill pattern which should also mask the walls when placed in the project. (You will need to check ✔  display when element is cut in its graphics setting )
