Column Grid Bubbles
18 ANTWORTEN 18
Nachricht 1 von 19
PhilvK
1033 Aufrufe, 18 Antworten
Column Grid Bubbles
Sometime last year there was a reply to one of my posts where I was asking how to get column bubbles to move with the crop box boundary. I can’t find that post, but I believe the solution had something do with making sure the bubbles had certain relationship to the crop box, and there was a second step to take. I just can’t remember, so does anyone know how to get the column bubbles to move once again with the crop box?
18 ANTWORTEN 18
Nachricht 2 von 19
als Antwort auf: PhilvK
Are you referring to the datums' 2D and 3D extents behavior?
Nachricht 3 von 19
@PhilvK
You can select the grids and assign a scope box from the properties. That constrained the 3d extent of them to the scope box. But it has little to none to do with how you exyend their 2d extent.
Nachricht 4 von 19
PhilvK
als Antwort auf: barthbradley
Believe it or not, I still don't I fully grasp what you mean by the datum's
2D and 3D extents behavior, since column bubbles only appear in 2D views.
In any case I am referring to when you initially create a view, a crop box
is created and the column bubbles are outside the box. When you stretch the
crop box, the bubbles move with it. If you change those bubbles' setting
from 3D to 2D and move them manually, they no longer move with the crop box.
A community member replied to me in a post (if I remember correctly), that
if you do something with the settings and make sure the crop box is in a
certain relationship with the bubbles, they will all move again. I just find
that post, nor replicate the behavior.
Nachricht 5 von 19
PhilvK
als Antwort auf: ToanDN
ToanDN - Please see my reply to Barth above. What I am trying to replicate
was done without using a scope box, which is also one of the things I've
never used, but will look into.
Nachricht 6 von 19
Viveka_CD
Hi @PhilvK
Are you looking for this post from last year that talks about column grid bubbles? See the solution by @ToanDN on this thread.
Nachricht 7 von 19
PhilvK
als Antwort auf: Viveka_CD
Thank you for looking, but that's not the one I was thinking about. It had
something to do with moving the crop box in a certain manner with respect to
the bubbles and changing them either from 2D to 3D, or vica versa and it
resulted in all the bubbles once again moving with the crop box.
Nachricht 8 von 19
When you create a view with a crop, the grids and levels switch to 2D extent to follow the size of the crop automatically.  You can change the size of the crop and they will stretch themselves to match.  But if you stretch them manually then they will lose the association with the crop forever.  There is no way back unless you recreate the view.
Nachricht 9 von 19
Are you sure you don't mean scope box? I mean if you have a Scope Box assigned to the view, you can toggle "Crop View" to switch the bubbles back and forth between 2D and 3D extents.
Nachricht 10 von 19
No.  I meant what I wrote.
Associate Grids and Levels to a Scope Box is to make sure all Grids and Levels having the same 3D Extent defined by the scope box, mostly used with a large scope box covers the entire extent of the project.  It prevents users from alter the 3D extent of Grids and Levels.  It has nothing to do with 2D Extent for views of partial plans, elevations, details, etc...
Nachricht 11 von 19
Sorry @ToanDN; that wasn't directed towards you. I was just trying to think what @PhilvK might be looking for.
Nachricht 12 von 19
PhilvK
Barth - Nope, what I was thinking did not involve the scope box, but what
ToanDN described above is close to what I recall. Sorry to bring all this
up!
Nachricht 13 von 19
@PhilvK wrote:
Sorry to bring all this up!
Nonsense! We're only at post #13; let's keep 'er rolling! Smiley (zwinkernd)
Nachricht 14 von 19
Viveka_CD
@PhilvK
Did you try turning off the crop and moving the grid bubbles (blue dot on bubble base)
After modifying the type properties for the grid family you can modify the length of the segment of the grid bubble.
You can propagate the datum extents (under modify grids) from one view to selected views to replicate the change (moved grid bubbles)
Is that close to what you were looking for?
Nachricht 15 von 19
Viveka_CD
@PhilvK Here is a screencast to customize the grids and grid bubbles. Does that help?
Nachricht 16 von 19
Corsten.Au
Nachricht 17 von 19
Viveka_CD
Hi @PhilvK
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Nachricht 18 von 19
PhilvK
Viveka - I still need to practice, but thank you and all for your help!
Nachricht 19 von 19
Viveka_CD
@PhilvK No worries.Smiley (fröhlich)
Do let us know when you tried the options and if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome.
