Column doesn't show up on Floor plan
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
kalktika
359 Aufrufe, 4 Antworten
Hello. My problem is that I can't see the columns that I place in the floor plan. I place a column in C0 with a depth of 200 and at the same time, I want to be able to see it from  the floor plan to align it exactly. How can I do it? Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: kalktika
Check phasing of the floor plan.
Nachricht 3 von 5
kalktika
als Antwort auf: ToanDN
Do you mean this ? Column has a mark on.
Nachricht 4 von 5
GustavoUbriaco
Hi!
You can use view range options as you can see in my example
Up here you can't see the column because it's out of the range also the column with top limit on the level
To see them I did change the view range configuration -100 mm there are unlimited option.
Gustavo Ubriaco Contreras
Nachricht 5 von 5
No I mean the phase of the floor plan where the columns is not showing.  If it is an existing phase and the column was created in a newer phase then the column does not show.
