Hi all,
Can someone tell me how to solve this edge wall with the column and the plaster on the part of the column.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Is it a structural column? Just create a new wall type with just the plaster layer, place them around the corner, do not let them join automatically with the main walls, and use Join geometry to manually join them with the main walls.
Yes, your solution is great, thank you a lot. Earlier I created architectural column (with size as marked with blue colors) and then structural column (with size as marked with red colors) - is that acceptable?
An architectural column inherits the wall finish layers automatically (see pic 1). A structural column does not. So another option for you is using both columns, an architectural column to get the finish wrap, a structural column to show itself (pic 2). Then you won't need to draw thin plaster walls as initially suggested and still have the same result (pic 3)
