Column Cut material appearance (Foreground vs Cut in plan view)
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
dbroad
893 Aufrufe, 2 Antworten
This morning I created several masonry column families, one architectural and one structural.  When I imported the architectural column into the project, the cut appearance worked correctly if the column was embedded in the wall but when separate, the column needed to be at least 4 to 6 feet tall regardless of the view's cut plane, in order to show the cut material pattern vs the foreground material pattern. BTW, this is for a foundation plan where the masonry piers should only be a few feet tall.  The material used was the brick, common from the imperial residential template.
I also created and inserted a structural column of the same material and it behaved the same way.  Is there some error in the cut plane for column materials?  The only way I could get it to work right was to model the column in place.  Has anyone else experienced these issues?
Architect, Registered NC, VA, SC, & GA.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: dbroad
Nachricht 3 von 3
dbroad
als Antwort auf: barthbradley
Thanks so much. That was it.
