Column boxing walls not bounding rooms, also room separation lines don't work
3 ANTWORTEN 3
Nachricht 1 von 4
SJM84
333 Aufrufe, 3 Antworten
Hi All,
I am trying to remove the area of the column boxing from the room. The thin column boxing walls are set to room bounding and are at the same level and elevation as the room but they don't bound it.
I also tried room separation lines but this didn't work either.
Thanks for any suggestions, Simon
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: SJM84
Are they Offset at Base? If so, adjust your Level's Computational Height - or don't offset.
Nachricht 3 von 4
Draw a Room separation line as shown below:
Nachricht 4 von 4
SJM84
als Antwort auf: ToanDN
There is already a room separation line in that location. I think the problem I am having is it is below the minimum area.
