Column Base/Top Level Parameter Greyed out
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
BigPicture045
344 Aufrufe, 6 Antworten
I am looking for how to change the base/top level.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: BigPicture045
What's greyed  out?
Nachricht 3 von 7
BigPicture045
als Antwort auf: barthbradley
The top and base constraints. Cannot select/adjust them.
Nachricht 4 von 7
Is it in a Model Group?
Nachricht 5 von 7
BigPicture045
It was in a model group. For some reason you cannot adjust this setting of the column in the model group even if the model group is in edit mode.
To fix I delete the column from the group and then out it outside the group and then add it back in.
Nachricht 6 von 7
So, the answer to my 2nd question is "Yes".    :zwinkerndes_Gesicht:
BTW, you can adjust a grouped column by Editing the Group.
Nachricht 7 von 7
therevitsith
Why can't you edit a columns base and top level when it's in a model group?
