Colors not matching
5 ANTWORTEN 5
Nachricht 1 von 6
lshannonEQEBT
1694 Aufrufe, 5 Antworten
Colors not matching
Hello everyone,
I have a weird thing going on that I just cannot figure out. I have a material on my floor that is set to display as a light grey (192, 192, 192), and I also have a filled region in a legend that has the same light grey to correspond to each other. When put onto a sheet, however, the floor is lighter (or the legend darker?). The floor plan is set to Hidden Line, so there shouldn't be any lighting that is affecting it (from what I can tell). I have also tried setting the coarse fill color for the floor to the same light grey and it is still showing lighter. Why could this be?
5 ANTWORTEN 5
Nachricht 2 von 6
GustavoUbriaco
als Antwort auf: lshannonEQEBT
Hi!
that floor is part of a revit link?
or maybe in the VG is the floors halftone
Gustavo Ubriaco Contreras
Nachricht 3 von 6
GustavoUbriaco
Your legend is ok, Is that view a floor plan, or section view? the surface pattern on the floor material is solod fill 192 192 192?
Here I have a legend with the floor in section. My surface pattern is the same that the coarse fill pattern.
Nachricht 4 von 6
Is the floor under the existing phase?
Nachricht 5 von 6
Same problem I'm also facing..
Is this problem resolved? And what is the solution?
Please reply
Nachricht 6 von 6
My guess is its a phasing issue. Is the element that's not showing as expected from a previous phase?
