Color Scheme not printing properly
Message 1 of 13
I have created a key plan for my project with a color scheme built in for areas in contract and areas not in contract. I also have these color schemes shown on my enlarged area plans.  Everything shows up fine in my Revit model (see attached image "the way it Should look". But when I print my color scheme covers up everything on my floor plan (see attached "the way it prints".
I have tried setting my color scheme to both background and foreground, nothing changes. I have tried turning onto wireframe and hidden lines. Again nothing changes... I am at a loss as to what to do. Any ideas?!?!
Thanks in advance!
Replies (12)
Message 2 of 13
dzanta
it is hard to tell the difference between the two attached images...can you elaborate?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 13
You can't see any of my walls, model lines, skylight windows, etc through the color scheme on the attach "the way it prints"
Message 4 of 13
dzanta
the view may be corrupt.  have you tried to create a new view?
Message 5 of 13
I have not. I will try that.
Message 6 of 13
That didn't work... Kate Van Hout Technical Designer 507-206-2143 | Direct [cid:image001.png@01D11B9E.A28D7FA0] 3777 40th Avenue NW Suite 200 | Rochester, MN 55901-1772 WidsethSmithNolting.comEngineering | Architecture | Surveying | Environmental
Message 7 of 13
dzanta
can you recreate the error on another workstation or is this error only occuring on this one file and on your station?
Message 8 of 13
I am having the same issues.  I created a color scheme as a test, it works properly in the Revit sheets, but when I print the image the color scheme is in the foreground, blocking all the walls, furniture, etc.  Any assistance regarding this issues would be greatly appreciated.  I also attached a screen shot of the color scheme in Revit on the left and the PDF print on the right.
Message 9 of 13
dzanta
have you tried printing to a different pdf printer?
have you tried this on another workstation?
is this occurring on only 1 file or any file?
Message 10 of 13
Mine was happening for all workstations.  I have not tried another pdf writer because I am using a work computer and I only have 1 option for a pdf writer. So far this has only happened for this one file because I have not used color schemes in any other project. (Mostly because it doesn't work correctly) I have to use Regions instead.
Message 11 of 13
RDAOU
@Anonymous
most  cases this occurance has to do with the PDF printer driver...(we have 3 pdf printers installed and it always works switching to another)
I would suggest that if can't install a different one and you are able to share the file; someone can maybe try it on a different printer
Message 12 of 13
Change your floor plan Visual Style from Wire Frame to Hidden Line
Message 13 of 13
