Color Scheme in Linked Arch Model Color Fill Only No Hatch
4 ANTWORTEN 4
Nachricht 1 von 5
634 Aufrufe, 4 Antworten
I am trying to represent a structural loading plan by adding load parameters to rooms in the Arch model. Im successful except the color scheme will only do solid colors and not hatch patterns. I have no idea why Revit would do this. Used the exact same setup for each just changed to hatch pattern and it just shows blank. Any ideas?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Should show pattern. What kind of view is it? Could be a scale issue.
Nachricht 3 von 5
als Antwort auf: barthbradley
I've tried structural plans, area plans and floor plans. And I've tried several different patterns and zooming way in thinking it was a scale issue as well but no dice.
Nachricht 4 von 5
It's because I am making arch rooms hatched in their linked models because it works fine if I change the color to a hatch in a room in my own model.  This is likely a job for enterprise...
Nachricht 5 von 5
Hi, Could you find the solution.?? I am also facing the same model in one of my project and surprisingly its fine in other project.
