Color Scheme - Door Panel, Swing lines will not plot in Revit Architecture 2011
Color Scheme - Door Panel, Swing lines will not plot. They show up in the view with the exception of the Door Swing line.. This color scheme is created for Floor Finishes. For the Color Schemes for the Ceiling Height and Finishes the Door Header shows up but does not plot either. I am creating PDFs for Presentations and plotting from  those. This is in Revit Architecture 2011.
LisaDrago
Can you post an image of what you want and what you are getting?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: [email protected]
kathryn.langan
I tried to set up a sample file to reproduce the behavior you are describing, but was unable to. My understanding of the issue is that you have set up a scenario similar to below (Color Scheme set up by Floor Finish), but when you print the view, the swing lines are not plotting?
2400i334963F2D02EDD12
If so, I would agree with LisaDrago that we probably need some more information about the problem.
  1. What build of Revit Architecture are you running (found in the Help pulldown > About dialog?
  2. Are your doors out-of-the-box families or custom?
  3. Do the Swing lines appear in the Print Preview?
  4. What format are you printing to? Do you see the same results in a PDF or DWF?
  5. Do you see a difference depending on whether your print is set to Vector or Raster Processing?
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Changed it to Vector Processing and that worked. Thank you !!
Other information is listed below if it matters at this point.
1. Build: 20100903_2115(x64)
2. The door is out of the box Revit.
3. The doors do not show up in the Print Preview.
4. Printing to PDF
Tony
