Color scheme and conflict with floors?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
tareqathamneh6QW84
537 Aufrufe, 4 Antworten
Hi, my color scheme does not appear as long as the floor within the room is there. If I hide it, I can see the color.
Below are 2 spaces given the same room category. the one to the right has its floor hidden. The one to the left keeps showing the surface brown color of the floor.
This is a repetetive problem,
Thanks!
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: tareqathamneh6QW84
@tareqathamneh6QW84
The room is getting bound by the floor element
Select floor >> from the properties palette; Make the floor NOT room Bounding
Nachricht 3 von 5
tareqathamneh6QW84
als Antwort auf: RDAOU
@RDAOU Tried, still not working...
here it shows the right colour blue beause floor is selected and turned transparent
when i release the selection, shows again the floor colour
Nachricht 4 von 5
RDAOU
@tareqathamneh6QW84
Check Floor material and also any overrides to the surface pattern of the Floor element (By Element/By Category/By Filter or by phasing). Solid pattern can conceal the color scheme.
Also check in section view the Lower/Upper Limits of the room, Level Above
Nachricht 5 von 5
Turn off any solid surface pattern of the floors.
