color of beam Direction Line
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
717 Aufrufe, 5 Antworten
When editing a beam system, the beam direction line is yellow on a white background and extremely difficult to see. Is there a way to change this? Many of our users are complaining about this. yellow beam direction line.png
2017.1
17.0.1081.0
20161006_0315(x64)
5 ANTWORTEN 5
Nachricht 2 von 6
m.voss.alvine
als Antwort auf: Anonymous
does that happen to be part of the pre-selection?
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Nachricht 3 von 6
chrisplyler
I don't know what that dashed yellow line is, but it isn't the beam direction indicator. The beam direction indicator is the two parallel magenta lines.
Nachricht 4 von 6
als Antwort auf: chrisplyler
The yellow line is the center line of the beam direction - I can't allign the system to another without it...
Nachricht 5 von 6
als Antwort auf: m.voss.alvine
Pre selection is set to a dark blue... I thought that was it but it wasn't.
Nachricht 6 von 6
