Color Gradient on Isometric Views/Plan Views
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
2744 Aufrufe, 8 Antworten
Is there a way to have a color gradient over areas either in a floor plan or isometric view in Revit? Or make the edges of a room color infill or filled region soft and fade out? The image below is the look I am trying to achieve if that helps.
Beschriftungen (1)
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Maybe you can get there with Masses that have the color gradient.
FWIW: https://wrw.is/color-fill-legend-in-a-3d-view-and-see-rooms-in-3d-in-revit/
Nachricht 3 von 9
Would you create the mass over the general area then alter the color options?
Nachricht 4 von 9
jorgedelacova7458
...and place the masses on a specific workset that can be filtered out of other views not needing them.
Nachricht 5 von 9
syman2000
I use Roof object as 3d room.
When you set the gradient, you can set the material as gradient and change the color to suit your need.
Nachricht 6 von 9
als Antwort auf: syman2000
That gradient looks amazing! How did you set up the settings on the graphics and appearance tab? I tried but I can't get the gradient to appear.  It still looks solid.
Nachricht 7 von 9
syman2000
I set the graphic display as realistic to get the gradient to show. Also I set the gradient texture size to be average size of the room like 10'x10' (3mx3m).
Nachricht 8 von 9
spm8C88E
I'm trying to achieve this gradient but in the realistic view setting I don't see anything, the roof is completely transparent. I can see some color in the shaded view, but not a gradient. When I render I get the gradient but no transparency. Any more details would be so helpful!
Nachricht 9 von 9
blank...
Does it have to be in Revit?
This looks like a hundred times easier done in Photoshop. Even the free https://www.photopea.com/
