Revit 2022 - While working on area plans, I run into a background processing error regarding the color fills. I am unable to change / adjust the colors fills and every time I try to alter area I received the "Color Fills calculation failed." popup. It seems this was a common issue in Revit 2016 but was patched out. This error has occurred on another coworkers computer in an unrelated model as well so it seems it is not just my machine. Any help would be most appreciated as this is holding up work. I have tried restarting revit, restarting computer, auditing, restarting the process, and reporting bug to no avail.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
