when I print a plan with a legend with a color fill scheme -
The plan appears normally in Revit like this https://goo.gl/3ZCGr1
but when I print it to pdf the regions hide all of the linework walls, doors, etc etc like this.. https://goo.gl/W7E7cZ
printing from r2019 to Bluebeam. What's the solution?
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Change your floor plan Visual Style from Wire Frame to Hidden Line
Possibly - using filters
When you see the final Bluebeam window after click OK to print, choose Lines Merge option.
