Color fill legend displays several floors
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1648 Aufrufe, 2 Antworten
I have faced a problem with color fill legends. I have a model of a three-storyed house and in the ground floor everything is o'key. However, on the first and second floors color fill legends shows rooms which are one level below as well (attaching some pictures to make everything clear). I checked that limiting view range to associated view does not help, but then I got stuck. I would highly appreciate if someone could advice me what to do to solve my problem.
Thanks in advance.
2 ANTWORTEN 2
Nachricht 2 von 3
VitorBIM
als Antwort auf: Anonymous
Maybe you haven't defined the computation heights of your room. You will be able to check it using a section view of the room that is causing the issue. Check if that works at 1:38 (It's in Portuguese but you can understand the process):
https://youtu.be/ON53uGsVonM?t=99
Nachricht 3 von 3
als Antwort auf: VitorBIM
Yes, that worked. Thank you very much.
