I wanted to ask about why the software keep changing the elements (Walls, Columns, etc..) color, knowing that I am drawing the same element in the upper floors, when i draw in the floor plans above ground level as shown bellow.
Sometimes the red elements are demolished--check Manage Tab>Phases>Graphic Overrides>Material>Phase Demo, click radio button to open Material Editor and check Graphics>Shading color
Tried this solution and didn't work, I am facing this problem only if I am drawing in plan views (not happening if I am drawing in 3D view).
Hi @Anonymous
Did you upgrade the model or install any updates recently?
Can you share the file with us to test further?
Looking forward to your reply.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Post screenshots of the upper floor plan view and the lower floor plan view properties showing the Phase and Phase Filter.
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Viveka CD
Just for info..
Revit default colours as per model, phase, phase filter, existing, demolished.. temporary.. etc..
