Color and appearance of the whole project changed by itself
8 ANTWORTEN 8
Nachricht 1 von 9
1318 Aufrufe, 8 Antworten
After I added some tree families to the project for landscaping , I entered the 3d mode to gets better view for my work. As I opened the 3d option I saw that all my buildings which previously were red and ocre are now shades of blue...the material is shown the same with the same appearance.. What's wrong and what can I do to make it right?
8 ANTWORTEN 8
Nachricht 2 von 9
Basam.Yousif
als Antwort auf: Anonymous
I don't completely understand your description.
  • Did you try to restart Revit? Reboot?
  • If you delete the 3D view and make a new one, what do you see?
  • Can you post a screenshot?
Nachricht 3 von 9
als Antwort auf: Basam.Yousif
hello.... not only did i restart the revit file but also checked it on the
next day(today) and the problem seems to be there... and i also discovered
the same problem seems to be there in all my cad files which was not there
before! and i meant the whole 3d viewing mode not just a view ...also the
renderings seem to show the original colors. ill attach a screen shot from
my rendered view and my revit
Nachricht 4 von 9
Could it be possible that you changed your display settings?
Depending on your display settings, the colours that you are seeing on your screen could be using the colour scheme under the "Graphics" tab in the materials, or the "Appearance" tab under the materials.
For example, if your display settings uses "Consistent Colours" your materials would typically show the colour of the material under the "Graphics" tab.  If you were in "Realistic" view, you would see the colour of the material under the "Appearance" tab.
Nachricht 5 von 9
I'm sure its in realistic.....I think my graphic card is not upto the
standard.
Nachricht 6 von 9
cbcarch
This could be a Phasing issue.
Check here:
Manage Tab>Phases>Graphic Overrides>Phase Status>Temporary>Material--this is set to Blue by default.
Also check the Phase Filter in your 3D View. Try changing it from Show Previous & New, to Show Complete, or Show All.
Note what colors change.
Check the Phase Created of your building walls, roofs, etc.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 7 von 9
als Antwort auf: cbcarch
thank you for your response...well the issue has seemed to solved itself. its back to normal now.
Nachricht 8 von 9
cbcarch
Hmm......... things do not "solve themselves". Something was wrong, and then something changed and fixed it.
Was it a Phasing / Material problem? Did that solve it?
Cliff B. Collins
Nachricht 9 von 9
Before checking the material and phasing solution mentioned in the previous
reply I thought of checking my project out before hand and that's when I
saw everything was normal again
