Collaboration on Local Connection
1 ANTWORT 1
Nachricht 1 von 2
ark.enihima
260 Aufrufe, 1 Antwort
Hi all!
In our office we downloaded Revit 2022 Trial on 2 pcs and tried to work with collaboration by creating a shared folder on one pc and giving access to the other. Than resulted that only the pc from which the central file was created in the shared folder could create a local file, the other one gets  grayed out "Create local file". We checked with our IT for the mapping to be the same on the two pc-s.
Could it be because our license is a trial?
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
EATREVITPOOPCAD
als Antwort auf: ark.enihima
The way I go about it collaboration is this: convert the project to a central model, save it, close the Revit file. Then copy and paste the central model and the new pasted file becomes the local model automaticly. So rename it and start working from it. If this doesn't work then the issue is with your shared folder and I would tell your IT guy to figure something else out, either adjust permissions or create a shared drive.
The definition of insanity is doing the same thing over and over again and expecting different results
