My company is trying to decide whether to buy Revit or not. Can you add COGO or coordinate points in Revit alone without using Civil 3d? I would need to put points on the job to export to a .txt file that the field tech would then import into his Trimble robot to layout the job on the lot. That is a very important feature for us.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
