Dear all,
What is Cobie in revit? Any one knows kindly post as a reply.
Lakshman
COBie is a supposedly universal to transfer the "I"nformation of BIM to building owners for FM. Essentially it is a spreadsheet with info about your model. Check out this article from the UK, explains it pretty well:
https://www.thenbs.com/knowledge/what-is-cobie
COBie is a data exchange format during the operation and handover phase of a project. This often takes the form of a spreadsheet that is peoplefriendly-readible.
By using the addin BIM interoperability tools of Autodesk. This spreadsheet can be generated directly from the drawing.
Later this spreadsheet can be used by the facility manager/owner during the operational phase of the building.
In the following blog you can find a basic explination of COBie.
https://www.biminteroperabilitytools.com/cobieextensionrevit.php
I added an empty spreadsheet as an example/spreadsheet.
