COBie add a new field
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1211 Aufrufe, 5 Antworten
there is any way to add a new field in COBie extension doesn't exist in the default.
5 ANTWORTEN 5
Nachricht 2 von 6
JasonKunkel
als Antwort auf: Anonymous
The columns in the exported spreadsheet for the COBie Extension cannot be modified at all. Those columns are very specific to the COBie standard and changing them would produce output that was not COBie compliant.
If you need to export data that is not on the standard columns, you can use the Attributes page. In the COBie Extension setup you go to the Attributes tab and select the extra parameters you want to export. Those then export for the corresponding exported components and types onto the COBie spreadsheet’s Attributes tab.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 3 von 6
steven.adams.yondr
als Antwort auf: JasonKunkel
Appreciate this is an old question but came across it searching for the same question. Our UK standard allows for additional fields to the standard. We need to add additional fields and not as attributes.
Nachricht 4 von 6
als Antwort auf: steven.adams.yondr
Hi Steven, Could I ask what standard it is? I am trying to find the text in your screenshot.
Nachricht 5 von 6
steven.adams.yondr
@Anonymous BS1192 Part 4
Nachricht 6 von 6
Thanks mate!
