hi,
or can someone upload the ribbon addin file? it seem missing in the folder
Hi @Anonymous
Can you make sure you have the COBie extension installed in this location:
C:\Program Files (x86)\Autodesk\COBie Extension\2018
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I have also installed Cobie Extension for Revit 2018 from this link http://www.biminteroperabilitytools.com/cobieextensionrevit.php but it only shows Autodesk Model Checker Configurator for Revit in the Start Menu. I also have my Cobie folder but there is no .exe file to run Cobie Extension
in C:\Program Files (x86)\Autodesk\BIT\2018\COBie
