CMU Wall with stacked wall and running bond with wall punctures
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
1958 Aufrufe, 15 Antworten
Hi everyone,
I was designing a wall which has stacked wall and have running bond in the small areal of the wall with gaps in it.
Any help with how to draw this in revit?
I am attaching the photo below which was done in sketchup
15 ANTWORTEN 15
Nachricht 2 von 16
als Antwort auf: Anonymous
I would split face ti change the material of the entire wall area, then create Opening family and place in that area on the wall.
Nachricht 3 von 16
I'd use a "window" family for that.
Nachricht 4 von 16
joe_keogh
Alternatively, you could create a cut-out and apply it to a new material, use "Split Face" or just draw a new wall over the top and use it to "Cut Geometry" out of the old one.
Cut-outs are created from a Black and White image applied to the material, where Black is Void and White is solid.
You can learn about cut-outs on AKN here, Cutouts Map
and here https://www.youtube.com/watch?v=IxSovnnFxpU
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 5 von 16
als Antwort auf: ToanDN
The problem with it is that when I having the applying the material I cannot see the block since, its the echelon CMU masonary, I don't know how to show them as blocks seperately
Nachricht 6 von 16
als Antwort auf: barthbradley
I tried doing that but in between I cannot get clear blocks
Nachricht 7 von 16
The blocks are defined by where you place the holes.  Anyways, another approach is using a curtain wall and alternate the panels with Empty panel and Concrete panel.
Nachricht 8 von 16
Not sure I understand. Are you saying the design intent is to have clear glass blocks embedded in the wall (represented by those red rectangles in your screenshot).   If so, apply a transparent material to geometry representing the block. Not different than applying glass material to the "glass" geometry in a OOTB  Window Family.
Nachricht 9 von 16
als Antwort auf: joe_keogh
This was exactly what I was looking for!
Thank you very much!
Nachricht 10 von 16
Really Helpful solution!
This is what was happening when I cut in the prfile
The thing that you werCapture.PNGe saying was not working out and I am attaching the picture below
Nachricht 11 von 16
If you build a wall-based Family, like a Window, and use a Void Cut in lieu of and Opening Cut, you can control the depth of the Cut Opening in the Wall. You don't have to penetrate the Wall fully.
Nachricht 12 von 16
The red that you see is just a small board in the back which is not significant in any changes in the design.
The design intent was to have a stacked block and running bond of a small chunk of space with wall punctures.
Nachricht 13 von 16
Got it.  You threw me when you said "I cannot get clear blocks".   Sounds like strategically placed and sized Openings would do the trick then -- if you want them actually modeled.
Nachricht 14 von 16
What does that mean, strategically placed and sized opening.?
I found that cut out method will be helpful.
Nachricht 15 von 16
If you are just looking for a Rendering Appearance of the Openings, then the Cutout method works.  I was thinking that you wanted to actually model the wall and the penetrations -- which look to be arranged in a pattern, and be of different sizes (e.g.  strategically placed and sized).
Nachricht 16 von 16
@Anonymous wrote:
The thing that you were saying was not working out and I am attaching the picture below
It comes down to matching the size of the curtain wall and grids with your material pattern.
