CMU Detail Component Light Weights
How do i change the line weight of the detail CMU
PijPiwo
Assuming OOTB family.
You can do it the project: globally - manage tab -> object styles -> expand detail items category and change the values of the lines as desired.
Or, locally per view - type VV -> and as above.
Or, in the family: select masking or filled region you want to change -> click on edit boundary on the ribbon and change the line subcategory.
FYI, the settings in the project, take precedence over settings in the family.
I wouldn't use it for 1/4" scale.
What @ToanDN said....bump up to 3/4" = 1' if a wall section or 1 1/2" o r 3" if details...
1/4" is gonna be a blob of ink at that scale.
