Closing workset for sharing model
3 ANTWORTEN 3
Nachricht 1 von 4
aleximonge
281 Aufrufe, 3 Antworten
I have a probably simple question, we are working on a shared model and one of the consultants is sharing their model but some of the worksets appears to be closed when we linked their model.
I am able to open it from the Manage>Manage Links>Manage Worksets.
But my question is how can I shared my model and have some of my worksets closed, and if the other consultants wabts to see it they need to do all this steps.
Thank you
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: aleximonge
You can close select worksets prior to saving/transmitting the model to be sending out.
Nachricht 3 von 4
aleximonge
Thanks for the quick answer, what you mean is that if I close my worsets, I synchronize with central. I close the model and I publish it will get shared with those worksets closed, or should I publish the model from the same session that I am working. Currently my models get autopublished everyweek because they are scheduled.
Nachricht 4 von 4
aleximonge
als Antwort auf: ToanDN
I was able to add it as a closed workset, only when I was loading the link and I specify the worksets that I want to open. But in my case was that the consultant shared the model with the worksets closed. I tried closing the workset, saving and loading and the worksets are all open.
I am attaching the image of what I achieve selecting the worksets that I want open when I link the model, but I would like to be able to control this before sharing the model
