Close Inactive Views Revit 2019.1
4 ANTWORTEN 4
Nachricht 1 von 5
GHASEM_ARIYANI
2746 Aufrufe, 4 Antworten
Hello
Why in 2019.1 Close Inactive Views The Quick Access toolbar has been removed from the toolbar.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
4 ANTWORTEN 4
Nachricht 2 von 5
aRcHiTeCt.JM
als Antwort auf: GHASEM_ARIYANI
.... same happened to me yesterday as installing the update
... here is the solution
https://forums.autodesk.com/t5/revit-architecture-forum/lost-the-x-option-to-close-all-open-windows/...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 5
Interest discovery, @GHASEM_ARIYANI.  Thanks for sharing.
Following....
Nachricht 4 von 5
aRcHiTeCt.JM
its been replaced with Close Inactive on the View tab.
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 5 von 5
GHASEM_ARIYANI
als Antwort auf: aRcHiTeCt.JM
Yes, We can turn it back with the right click on the tool.
But why was removed from the default mode? In my opinion, there is a mistake in coding and should be solved.
