I have a problem with a Revit Model. I created coordination model which contains only multiple DWG links. This DWG contains 3D solids, so I link them in model in place family to see all solids cuted in section. At start model with links size was 100 MB, now its 300 MB, so I copy this model and delete everything in model include imported in family categories. Cleen model with nothing inside has size 175 MB. I think that model still include some artifacts. Is it any possibility to clen database of this model and reduce a size of it?
Hello.
Have you tried to use purge?
for sure not everything but look inside the purge which elements you dont want
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
alt="Autodesk Expert Elite" style="width: 150px; display: block; margin-bottom: 10px;" >
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
Also I recoomend to Audit your file,when you open check the small edit
Mahmoud Zeidan
Yes, I used all of this methods, problem, I also copied this file and delete everything inside, used purge, and audit method, including delete all import in families subcategories. And full empty file has 175 MB, so it is irrational that empty file weight so much
Do your file contain raster images? Upload the sample file so we can look at it
