I am trying to clean up the 2 roof beams that are going into the ridge beam so i get the clean straight look of the roof beam ends and not the angle look, if i drag the end of the beam past the ridge beam. How do i accomplish this.
Mike
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Try:
-Join Geometry
- Place a Reference Plane on each side of the Ridge Beam, and then use Cut Geometry and trim the rafters to the Ref. Planes on each side.
-You can also try the Coping Tool.
Good deal--So, did it work?
If so, which method?
Please reply back and accept as solution.
Went with the ref plane solution. works great, just dont delete the ref. planes after cause it goes back, no biggie .
Tjanks
