cleaning out materials asset browser
I am cleaning out our office Materials Asset Browser, but before I delete something important, is there a way to tell if an asset has been assigned to a material in the materials browser?  I don't want to delete something that is actually getting used.
Jason_S
If you use the Purge Unused command and scroll down to materials you should only see the materials not being used in the model. Found under the Manage Tab then Setting Panel Purge Unused.  With this you can select just the items you want to remove from the model that are not being used at the time of running the command.
