Clean Wall Join 2 different wall types
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
EATREVITPOOPCAD
521 Aufrufe, 7 Antworten
I have 2 different wall types, which are identical other than the fact they are different types (have different names)
If they were the same type, they would be connected with a clean join in a pasted image below.  But after I duplicated one of the wall types, the walls do not join this way anymore. How can I make it happen?
The definition of insanity is doing the same thing over and over again and expecting different results
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: EATREVITPOOPCAD
Are the walls in the same Phase and is View Phase Filter set to Show Complete?
Nachricht 3 von 8
Copy paste the two walls to a new file and share it.
Nachricht 4 von 8
EATREVITPOOPCAD
So I realized what causes this behavior, still curious if there is a way to get around it. If the view's detail level is set to course then the walls clean up properly. But if the view's detail level is set to medium or fine then the outer edge cleans up, but not the interior....
Attached a partial model.
Nachricht 5 von 8
Because you have all layers in Core.  Move finish layers out of core and differentiate finish/core materials.
Nachricht 6 von 8
Why are all your layers the same priority and core layers?  Seems odd.
How about this instead?
Nachricht 7 von 8
Nachricht 8 von 8
EATREVITPOOPCAD
This was it! Thank you for the link @barthbradley very helpful
