Classification Manager Add-in _ IFC export
0 ANTWORTEN 0
Nachricht 1 von 1
mairh_tsek
341 Aufrufe, 0 Antworten
Hello all,
I use the classification manager add-in in Revit 2018.
I used a custom excel file with the classification system that I need and in Revit I created the equivalent parameters.
In the first image you will see the classification systems that I assined in a wall.
I want to export these parameters in an IFC file. I tried first to export two of the four custom parameters that I created in Revit (image 2) but in Solibri I get only one (the code parameter - image 3 )
Question:
Do you know how/if it is possible to export all the custom parameters that I created in Revit in a IFC ?
Thnak you in advance !
0 ANTWORTEN 0
