In my North elevation, the render of the cladding is displaying as a lighter shade of grey. On all the other elevations, it is displaying correctly. See the snip attached; the darker grey (East) is how it should look.
All walls are using the same wall type with the same cladding material; There are no graphic overrides; and sun paths are turned off. Does anyone know what I'm doing wrong?
Set both Views' Visual Style to Consistent Color and both Views' Phase Filter to "Show Complete".
Hi @studiorodway
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
