Civil 3D Boundary is not showing correctly when imported to Revit
4 ANTWORTEN 4
Nachricht 1 von 5
336 Aufrufe, 4 Antworten
Hello Revit community,
Any idea why I am getting this warning below:
It happens when I link CAD from Civil 3D to Revit. Image below shows aside from the boundary (PINK LINES) I created, it also generates the whole toposurface although I did not select it from the list. I only want to see the boundary surface.
Thank you in advance, cheers!
Richie
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
I don't know if I understand correctly, but it sounds like you want to create a Split Surface (on the Massing & Site Tab).
Nachricht 3 von 5
als Antwort auf: barthbradley
Hi @barthbradley,
I already tried that but error. See below:
And I am not sure if this is the proper way to do it. Or maybe I am doing it the wrong way. I dunno if it has something to do with Site Settings.
Thank you for the reply @barthbradley.
Cheers!
Nachricht 4 von 5
yurikim
Thank you for your posting @Anonymous
Have you tried to import through Site Designer? Try this and see if you can get more accurate result.
Yuri Kim
Product Support Specialist, AEC
Nachricht 5 von 5
the boundaries can't touch each other. Modify one of them.
