Circuit Sequnce
4 ANTWORTEN 4
Nachricht 1 von 5
357 Aufrufe, 4 Antworten
Circuit Sequnce
How to make circuiting sequence starts from 01,02,03 instead of 1,2,3
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
Diego.Faria
als Antwort auf: Anonymous
You can choose the "Prefix" option in the panel that controls that circuit. Remember to put both the Prefix and set the Circuit Naming as Prefixed, as shown in the picture.
Diego Faria
LinkedIn
Nachricht 3 von 5
als Antwort auf: Diego.Faria
The circuit number should start from 01, not from 1,
if I give circuit number like 01.....it will circuit prefix as 01,02,011,012....so
but I need it as CB01,CB02,CB03.....CB11,CB12
Let me know anyway can we achieve this
Nachricht 4 von 5
Diego.Faria
In that case, I don't think there will be a setting that does that, since it's only for the numbers from 1 to 9.
Do you need those values only for scheduling purposes or just tagging?
If you only need it for tagging, you could create a duplicate of your regular circuit tag with the 0 built into it, just for those 9 first circuits.
Diego Faria
LinkedIn
Nachricht 5 von 5
Judy_S
Hi, salagams,
I'm Judy, a Revit specialist. I see you have a question about adding a 0 to the single-digit circuit numbers in Revit. Did you find Diego's suggestion helpful? There isn't any way to change the way these numbers are displayed in Revit at this time. If this is a feature you'd like to see in Revit panel schedules, you might want to post the idea on the Revit Idea Station, and include a description of why you would like to see this feature and why it would be valuable to your business. Or, if someone else has already posted the idea, you can vote for it.
Please let me know if there's anything else I can do to help!
Best regards,
Judy_S
Judy.S
Product Support Specialist, AEC
Link Name | Link Name | Link Name | Link Name
