Chromium Host Executable Processes Running in the Task Manager
2 ANTWORTEN 2
Nachricht 1 von 3
435 Aufrufe, 2 Antworten
Why are these processes running in the Task Manager, when none of the Autodesk component are being used. It discharges the battery, it's noisy and and occupies a lot of laptops processing capacity. Please give solution without physically disabling them in the Task Manager which then stops the programs functioning properly? Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: Anonymous
Log out of A360
check this..
https://forums.autodesk.com/t5/autocad-lt-forum/chromium-host-executable/td-p/5853579
Corsten
Building Designer
Nachricht 3 von 3
als Antwort auf: Corsten.Au
tried but three of them still running while working on revit 2017.
