Choise correct texture for wood finishes
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1100 Aufrufe, 4 Antworten
I should find texsture like first image.
Someone suggest me some patterns but I can't find on internet.
Someone can help me on this, please?
.rvt file is attached
Thank's.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Are you unable to Google Images for Clapboard Siding?
Nachricht 3 von 5
Ah! I see what your problem is, @Anonymous !  A lot of your exterior walls are facing the wrong direction!
Simple fix. Change the orientation of those walls that are facing the wrong direction, and voila! -- all is right as rain.
Does that merit a Solution Credit?
Nachricht 4 von 5
als Antwort auf: barthbradley
@barthbradley  yes, but I wanted the shiungle .pat.
In my Revit there isn't this.
Thank's
Nachricht 5 von 5
Pattycake_Kyle
We got a couple for download here. If you cant find what you need, we also give you the ability to make your own from AutoCAD or draw in web. Just let me know if you need help with this - email: hi@pattycake.io
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
