I have a chimney breast that I need to model in a roof space. It reduces in width as it rises up till it goes through the roof. I could do an extrusion but is there a way to use a wall to create a similar thing. I'll try and post a photo of the sort if thing....Thanks Mike
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Looks like it was built by a drunk person.
Got 2023? If so, you now have the prefect occasion to put that new Slanted Walls feature to practical use. Yippee!
If not, Walls and Floors will get you there no problem.
...actually, I used a Roof by Extrusion, not a Floor. It was faster. You can use either. Both will be a Attach Top/Base target for Walls.
