Check spelling - Adding a new dictionary
5 REPLIES 5
1060 Views, 5 Replies
Is there anyway to add another language (i.e. Dutch , Greek, Catalan...) to the ones already preinstalled in Revit in order to use as the main dictionary  for check spelling ? .Thank you.
Labels (1)
5 REPLIES 5
ennujozlagam
go to options and change and see if helps. thanks
in reply to: ennujozlagam
Thanks for the reply but I don't think that is the solution .
Both additional dictionaries are dependent on the main one .
As fas a as I can tell you cannot add a new dictionary with a different language in the additional dictionaries box.
nmarcelis
@ennujozlagam
Every day there's something to learn about Revit. As I also speak Dutch, I never knew these options existed.
Revit Certified Professional Architecture, Structure and MEP.
_Vijay
in reply to: _Vijay
Thank you Vijay .
But if I am not wrong , that means that you cannot spell check in any other language outside of the 10 or so languages preinstalled in Revit   . I find it a bit odd that Revit doesn't allow the option  to install other dictionaries ,  but maybe that's just the way it is,
Forma Design Contest
Technology Administrators
