I am adding Area view above Floor plan view, but it is masking the Floor plan. When I change the order of inserting the views on the sheet everything appears properly. The bad part is that all the sheets are ready with the inlined Floor plan views and I have to insert the Area View , remove the Floor plan view and then re-adding the Floor plan to appears above the Area View- this will take hours of boring work. Is there a way to quickly change the view order (move forward/back) on the sheets? Thank you.
