Changing the swing of a door on plan view
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
12626 Aufrufe, 4 Antworten
Would it be possible to know how to change the swing of a door on plan view other than 90 degrees?
Thank you.
4 ANTWORTEN 4
Nachricht 2 von 5
Revit_Whisperer
als Antwort auf: Anonymous
You will need to modify the family to add a different door swing.
Here is a blog on one way to do this if you just want to have the two different swings 90 or 45.
http://blogs.rand.com/support/2013/08/revit-adding-an-angle-parameter-to-the-door-swing.html
If you want to add other increments you would need to add an angle parameter, but that is a bit more difficult if you aren't used to working with modifying families.
Nachricht 3 von 5
jemiahjenkinsLGKD5
Just select the door opening. In the properties window is a swing angle cell under the construction parameter. Type in your desired angle.
Nachricht 4 von 5
mhiserZFHXS
als Antwort auf: jemiahjenkinsLGKD5
That's assuming he has a remotely well built door family. There is a lot of junk floating around out there.
Nachricht 5 von 5
c_thorne5T77F
wow SO EASY
