I have just created a topo surface from the Survey Data which is at about 100m above sea level and I would like to change the elevation of my building so that it sits in the topography.
Also, I would like to know if Revit can calculate the most optimal way of determining Structural Slab Level based on minimising cut and fill.
Thank you in advance
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
may check it here. thanks
This link is no longer available and I'm wanting to accomplish the same thing. Can someone share a new link or propose a solution?
