changing the colour of glass
7 REPLIES 7
Message 1 of 8
stevensonJQWEF
432 Views, 7 Replies
Hi guys,
I have edited the material, because I would like to see a ´visible´ glass in my model (so one with a slight blue tint)... however even though the material is changed, (and used here), in the model it is completely transparent.
Is someone able to tell me why this is?
Thanks in advance!
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
blank...
in reply to: stevensonJQWEF
You set the foreground color, but you left the pattern at "none". Set it to solid.
Message 3 of 8
Set View Phase Filter to Show Complete.
Message 4 of 8
That setting is for shade mode and consistent colors mode.  To show the color in hidden mode, set the color to Surface pattern.
Message 5 of 8
stevensonJQWEF
in reply to: ToanDN
Hey guys,
I have made the changes that you suggested, but still the glass apears completely transparent.
Do you have any other suggetions?
Thanksss, Nina
Message 6 of 8
Hey guys,
Thanksss, Nina
Message 7 of 8
ridantuo
Use render appearance is unchecked.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Message 8 of 8
Have you checked if there's a filter in your current View Template if you have one.
Forma Design Contest
Technology Administrators
