I have a door tag that shows rough width and height and even when I write down 19 it corrects it to 19.0. I want the door tag to show 19x23, not 19.0x23.0. How can I change the values shown in the photo from having one decimal point to having none?
There´s nothing in the family where I could change that the value doesn´t come from project units defaults (at least couldn´t find it) and even when I tried changing the project units´ length value it does nothing for these numbers.
How is this done?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Edit the labels, field format, untick Project default, snd change the unit decimal place to 0.
You need to dumb it down for me, I know how changing the default works but I can´t find it anywhere. So you mean that in the door tag family I need to change this in the door tag family or the single label itself? I can´t find that anywhere. Is it possible that it´s missing and I need to add it myself or what?
If you could write a more detailed chain of how this is done (or show in photos) I would really appreciate it.
Don't change the default Project settings. Change the label format in the family.
Thank you! I never realized that that button activates when you have the label parameter activated!
