Hello
I have a problem due to chaning size of created void sweeps in family, I have a beam family which contains 4 different separate parts of beam. I tried to use nested family face based for voids elements, but unsuccesfuly because each "beam part" has his own host rules - when i place nested family on 1 part and make array then on the rest parts voids or even shapes of voids won't show up. I made void shapes in original family, constrained array in a way which I wanted then after uploading it in to a project all works but when I want to change the sizes of holes error pops out.
Any ideas?
Also attached file with family (2017)
Hey, I tried this and it doesn't work for me because of this 4 separate parts of beam which are needed
Just curious about the construct itself. What's it to be used for? I see it is Categorized as Structural.
...also, I don't understand what you are trying to do or what you can't do. Could you eleaborate, please.
