Changing section depth break all detail items on view?
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
826 Aufrufe, 8 Antworten
Why would changing the section depth un-group all the detail Groups on the section view?
I can cut out these items, edit the section and paste them in place, but that's extremely inefficient.
8 ANTWORTEN 8
Nachricht 2 von 9
cbcarch
als Antwort auf: Anonymous
Changing section far-clipping does not Ungroup anything.
Not sure what is happening. Can you post a screenshot or perhaps a reduced size Revit file?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 9
als Antwort auf: cbcarch
I wish! :enttäuschtes_Gesicht:
Here is a screencast http://autode.sk/2EJq7rD
I did not create this section, just modifying it now.
Nachricht 4 von 9
cbcarch
Try placing a new Section, adjust depth and see if same thing happens.
Also note difference between a "live section" and Section Referencing Other View"--that could be an issue with the Group if section depth gets changed.
Cliff B. Collins
Nachricht 5 von 9
This is the only section that reacts this way. I was able to wok around it by cutting out the elements that we exploding, modifying the section depth and pasting the elements over it. Still, puzzling and annoying.
Nachricht 6 von 9
cbcarch
What happens when you place anew Section ("live", not using Reference Other View) in the same place? Do the Groups get Ungrouped?
Cliff B. Collins
Nachricht 7 von 9
These are detail groups, so if I draw a new section, they won't be there
Nachricht 8 von 9
Some elements in your detail group may be constrained to model elements.  When you reduce the section view depth, those model elements may disappear or appear in a different way (a ramp for example).  That may break the constraints of the detail elements and subsequently break the detail group.
Nachricht 9 von 9
als Antwort auf: ToanDN
Thanks Toan, I figured the other user did this by accident, but hard to figure out what another person did wrong. Also, I tend to avoid 2d work and this is a lot of hidden 3D and a lot of 2D, so annoying.
I think for the future, I will do a move "disjoin" at a distance of zero to the problematic objects if I see this again.
