Changing plumbing fixture materials for rendering on Revit
I received plumbing model and now I want to merge it with my architectural model for rendering & Virtual Reality. I need to assign a new material (Original is white, see attached). How can I assign a new material to these existing pipes? q1.PNG
L.Maas
You could use object styles (MEP Fabrication Pipework)
Louis
Please mention Revit version, especially when uploading Revit files.
...might be easier just to assign a Render Appearance to the material that the piping is presently using.  Just a thought.
Thanks for your help. I'm a beginner. I did what you said, but I see a lot of segmentsq1.PNGq2.png that I don't know what those are and what to do with them all? please see attached.
Thanks, my friend. It was a big help. I appreciate it. worked!!
