Changing Plate Height
3 ANTWORTEN 3
Nachricht 1 von 4
575 Aufrufe, 3 Antworten
Hi, Question from a non-architect regarding modifying the 1st and 2nd level plate heights for a 3,000 SF 2-story single family residential home.  Is this quick and easy to do using Revit and what is a ballpark amount of time it would take by an architect experienced with Revit?  The windows and doors on both levels are floor-to-ceiling so their heights would need to be to be adjusted as well.  Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
gerry4KN7C
als Antwort auf: Anonymous
Typically I use Levels for Pl.Hts. - so its no question, and I can get roofs to sit properly at correct heights.  If you have your walls and other things constrained to your levels, then changing the height is no issue. Windows, have a sill parameter which would be the offset from the level. When you move the level up, the sill parameter will remain consistent across the board.  Quick Fix.
Nachricht 3 von 4
It depends how it was modelled - it could take a minute, or three hours.  If everything is connected to the level, it's a matter of changing the levels.
Nachricht 4 von 4
There is no "ballpark". You are going to need to get estimates - or trust the Architect you are working with.
